HI all. at the moment i have a question i have created a page which has a fixed header which goes across 100% of the page even when its enlarged but the problem I have is that this has to stay at the top even when the page scrolls down as the page will have smooth scrolling
so the idea is that the header which will have the nav in wont move so really when the page scrolls down
(links are anchors) the user always will see the nav bar at the top
please can someone help
As long as you don’t make your header an inline object, you can get
this effect very easily. Draw an HTML box, position it at 0, 0, and
set its width to 100% using the Inspector. Then change the Position
picker from Absolute to Fixed in Window.
Now anything you place in or on that HTML box will stay in view no
matter how the rest of the page scrolls. Be sure to use Item / Bring
to Front from the main menu so everything else will slide under it.
