I wondered if anyone had suggestions on how to enable the responsive navigation to bounce back up automatically after clicking to the page you want to go to so it just shows the main navigation header. Otherwise on the mobile, if the navigation menu is quite long, it hides most of the page. I know it is possible to click the hamburger to hide but automatic would be neater and more user friendly.
Hi Mog,
Nice looking site. It looks like you’ve found a use case that wasn’t considered when the responsive menu was created.
I can think of two ways of putting the responsive menu away when a link is clicked but neither is elegant;
Somehow try and append an onclick event to each anchor tag to put the menu away using JavaScript;
This will cause the page to reload AND jump to the correct anchor point and in doing so will put the responsive menu away for you.
