That actin makes the image slide down, but when the rollover goes away the
image does not slide back as it does in the demo page.
On Apr 10, 2011 10:32 AM, “waltd” email@hidden wrote:
I’ve tried in the past to make rollovers with effects like this using
the built-in Actions, and discovered this shortcoming as well. I don’t
know how you would get around this with the FX Actions, but I know
that Tim’s CSS3 rollovers can do this very easily.
away the
I thought you could only use the CSS3 action to make the item rotate?
away the
Sorry, you’re right – it does appear that’s the only transition on
order at the moment. The jQuery effect does use CSS3 transforms on
supported browsers, so the effect is possible in CSS3, just not
exposed in the Action (yet).
