[Pro] Flexible Height with minimum value
Hi all,
is there an option where I can set a html-element to a flexible height BUT with a minimum value/height?
I using Freeway Pro 7.
Greeting, Tobi
Yes - this is surprisingly enough called min-height and part of inspector’s height dialogue.
Hi Thomas. When I choose a min-height, the html-element won’t resize, when I change the windows size.
can you give us an example-link? I’m afraid that I don’t know what you’re after.
Here can you see that the image resizes when the window size changes. Unfortunately the minimum size is not set and when the window height gets to small the image gets small too.
With a minimum height I’ll stop the image downsizing for example at 100px.
So the html-element shall resize with the window size but stop (down) resizing at 100px.
I think you should more deal with a min-width rather than a “height” - but I might be wrong here.
And don’t think too much about browser-window sizes but more on devices and the situations there.
Is this your example you struggle with? Cause it works pretty well (I think the width/height attributes are coming from js) and it’s not Freeway.
As I already said:
I think it’s about arguing with a width (and height auto) instead of width and height 100%. But honestly I’m way too shorthanded to really help you out here.
