If you will look at the head section of your page code for each of those
pages, you’ve imported the Google font ‘Roboto’ differently - one with a
font-weight of 100 (very thin) and one with font weights of 300, 400, 500
and 700.
First, you should be consistent with your google font code for each page.
Don’t import any fonts you don’t intend to use and try to use the same code
for each page. In short, be consistent.
Second, once you have settled on which weights of that Google font you want
to use, then only import those weights.
Finally, be sure to specify the font-weight numerically to match Google’s
font code. Freeway generally uses words like ‘bold’ or ‘normal’ instead of
numbers, but you can Extend a style with font-weight
and the number value
(400 is normal, 100 is very light, etc.) Be sure to match the Google weight
number - don’t invent one.
Best of luck.
On Mon, Oct 6, 2014 at 4:13 PM, Erik email@hidden wrote:
Hi,
Something strange here:
http://hortus-coaching.nl
http://hortus-coaching.nl/contact.html
I use the same styles on these two pages,
The font on the contactpage looks strong, the other pages thin somehow?
Both have the same master and as far as I can see no different settings.
The strange thing is that this happens in firefox and Chrome but not in
Safari?
Anyone an idea what cause this?
Thx
Erik
hortus-coaching.nl
