[Pro] Font
I think I know the answer but maybe I’m wrong. The font that says “better bibs” up top changes when i look at it on my phone and tablet. Is there anyway to fix it, or is this because the font is not installed on other devices?
www.hgrantdesigns.com/betterbibs1
Yes
Look at some of the Web Font actions to include it for everyone
ie WebFonts, Caxton or use Google Fonts
What is a good script font to use that is both desktop friendly and mobile friendly? Any ideas?
Also, how do i import a font that i found in google fonts into freeway?
Here’s something I wrote on that -
http://cssway.thebigerns.com/workbench/google-fonts/
And just reiterate what Keith wrote.
Search FWT - there are literally dozens of threads on Google Fonts etc.
Yeah, i got that, but now i can’t get the font into freeway, following the instructions
You don’t actually need to install the Font for it work - it relies on an internet connection to the Google server to display properly.
If you want the Font to be viewable in FW’s design view that is a different story.
Personally I try not to install the Font as you often don’t see what your visitor will see.
What part of ‘installation’ are you struggling with?
I got to the part where it says " before the </head" and then I couldnt add it in fonts, that’s where i was struggling. I could not add it at all
was trying to add the font “lobster”
… and that’s what I did:
http://www.kimmich-digitalmedia.com/videos/015_the-coding-episodes-part8-google-webfonts
Thomas… YOU ARE A LIFE SAVER!! THANK YOU SO MUCH FOR THE VIDEO!
As always, it’s best to check the Softpress KnowledgeBase. See http://www.softpress.com/kb/questions/276/ and http://www.softpress.com/kb/questions/455/. That page should always be your first port of call.
Doesn’t want to install. I’ve done it exactly what soft press is saying, 5 or 6 times and nothing.
