New entries appear correct when setting them up, but the different fonts and font sizes are reduced to just one in preview browser. See the section in italics (2nd entry on the page).
This was set up using a similar style to the first entry. But all the styling has disappeared when uploaded. I am using Freeway Pro 7 and Yosemite, and have never had this problem before. It happens whether I use a new text box or, as here, just add to an existing one. Help please!
When I’ve had an issue like this I have found the best solution is to highlight all the text and any blank lines above and below the block and then select “No style" from the styles palette. I then reapply the styles and the problem usually goes away.
If you look in the syles palette it’s most likely you have had some temporary styles created (called style1, style2, etc) which can confuse the output. You should always aim to have no extra styles listed other than the ones you have created.
On 3 Jan 2018, at 10:00am, Philip Grosset via freewaytalk email@hidden wrote:
