Hi All
I’m running into a small problem; on my form I have 2 buttons “de heer” and “mevrouw” (Mr. & Ms.). The person who fills out the form clicks one of them. However, in the e-mail I get the message say’s: “Mr. Ms on”! This way I still don’t now who is contacting me. I would like something like “Mr on” “Ms Off”. I think you now what I mean.
Change the checkboxes to radio buttons, give the same name to those radio buttons but set the values to what you want sent in the form.
Personally a drop down menu might be better for what you are looking for, in English you might have: Mr. Mrs. Miss. Dr. etc. so a menu would seem more suitable, that is not to say you should not use radio buttons if that is what you want to use.
HTH
On Jul 5, 2013, at 9:16 AM, Robboxxx wrote:
Hi All
This tells me it is PHP Feedback Form: action="offerteaanvraag-go.php".
Look carefully at the instructions at Tim Plumb’s site (http://freewayactions.com) for this Action. The field names must be named precisely (and in English, and case-sensitive) for the sender’s e-mail address and full name to be concatenated into the message by the handler code. You may name any other fields however you like (as long as you follow the rules for variable naming*) and they will be passed through exactly as written.
*A valid variable name begins with a single letter a-z or an underscore, and may be followed by as many other letters or number 0-9 as you like. NO other characters at all may be used, particularly extended (ö é accented or “high-bit”) characters, and especially no other punctuation (besides the underscore) or spaces.
On Jul 5, 2013, at 1:45 PM, Mike B wrote:
No, but I can’t really help you there as I am not sure what action are using for the form handler?
On Jul 5, 2013, at 2:44 PM, Robboxxx wrote:
Another question about this form: after sending the e-mail <<>> shows as sender in the receivers e-mail. Is this normal?
Thanks a lot for the help. All works now the way it should. Although I have to admit that my head turned red when I discovered that I completely overlooked the e-mail input name…
