I’m creating a form but the text fields i create are not working properly ie they dont return when the text hit the side of the field they just keep going on? I’d expect the text to automatically go to the next line? any ideas? Even the force action to make the fields deeper - the text i input just stays on one line never returning? Hope this makes sense??
can have a look here - it doesnt work either - even though i know my server supports PHP?
thanks
Mike B - thanks Ill have look at that - can i create a form with text areas?
Yes, if you want the user to write a message or comment then use a ‘Text area’ for that and not a ‘Text field’, then the text can be written over several lines.
