Is there a way to get form mail sent back in a more presentable format?
Or, is there an way to extract or import the data into another program to save having to cut and copy the data out?
What method are you using to create your form/processing? Are you using Matts’s FormMail?
No, I use formmail.pl suppled by UK2.net
Unless you can modify the formmail.pl file then no.
VicH1
(VicH)
March 12, 2012, 4:32am
5
Forms to Go by Bebosoft is a bit more complicated to set up in Freeway than most of the form actions available but has the ability to format emails. http://www.bebosoft.com/products/formstogo/overview/
Hi Vic,
agree that F2G is an enhanced way to tackle forms in Freeway however I think the setup in Freeway is fairly easy.
It’s much more complicated to set all stuff in F2G but I dug out a screencast (probably the only one left of Dan) on:
http://formstogo.stationv.com/danjaskarvideotu.html
that should clear up the basics.
I do nothing else than F2G - unfortunately with a limited timescale to dive much deeper in the theme (uploads, styling …) but would recommend it every time it comes to forms in freeway.
The caveat: F2G is not free (but I never regret once purchased it).
