The code that I posted needs to be edited and saved as a plain-text file with a .php extension. You must use a programmer’s text editor, like the free TextWrangler from BareBones Software, and you must not use any curly quotes or other typographic niceties in it – they just break the code.
Upload it to your server using Transmit or Fetch or another FTP application.
When you visit it in your browser, use the entire filename == your.server.com/newscript.php
You should see Sending mail…Done in the browser as plain text. There won’t be anything else to see. But then check your in-box and see if one or both messages made it to you. If you get both, then that rules out what I was supposing might be what’s going on. If you only get the one from the user that actually has an account on your server, then you can start to figure that you need to configure PHP Feedback Form to ignore the user’s e-mail, and send the messages to you from an authorized user.
On Apr 22, 2014, at 5:18 PM, sampolfonz wrote:
Hi Walter,
Thanks for the help.
So, are you saying to take the copy you have given me, put it into a text document, save with the name of newscript.php (extension of php), upload to the server and try accessing from a browser with this path:
Internet Provider for your home, Home Phone Company, TV, NITCO Northwestern Indiana Telephone Company Hebron, Rensselaer, Valparaiso, Chesterton, NWI
or are you saying to change the form script in the Freeway document to this new script?
Not following exactly, sorry.
Thanks again for the help.
Rich
