[Pro] Forms To Go/Freeway
i’m just about to publish my first Forms To Go/Freeway form but I have hit a snag and don’t know what to do or what FTG means. When I published my php script using FTG it warns me to ‘change the ACTION attribute in the FORM tag to “nameofscript.php”’
I’m not sure how to do this can anyone help please?
I assume that it is in effect pointing the form results to my script to process it?
thanks
In your form page in Freeway, open the Page / Form Setup dialog. You
will find a field in that dialog labeled Action, and you should change
this to whatever FTG named the form handler script when you generated
it. Upload that handler to the same folder as your form, so you have
form.html
form-handler.php
in the same folder as one another.
thanks walter - i’ll give it whirl tomorrow and post the results.
rgds
jim
