Okay, this looks to have been created by taking the Search field code from a page that had both the Simple Site Search field added AND the SSS Submit Action on the button. That’s not what I intended.
Also your code is invalid. I had to copy and paste it out into a text editor so I could see what was going on, but here’s your code cleaned up so it’s readable (but not changed in any way). See if you can spot the basic problem here:
<div id="SiteSearch" class="f-ms">
<p class="f-fp f-lp">
<form action="sitesearch.php" method="get">
<div id="PageDiv">
<input id="Button1" class="f-ms" type=submit value=">" name="s">
<input id="Searchfield1" class="f-ms" type=text placeholder="Search" size=35 name="q">
<input name="t" type="hidden" value="1388507934270">
</p>
</div>
</div>
</form>
</p>
</div>
I’ll give you a hint. No two things on the same page may have the same ID. You have two duplicates here (one is inferred, since I didn’t include the outermost #PageDiv in this code snippet).
Working from this, here’s the only thing you should be pasting into your Markup Item, and your Markup Item must be a positioned element, so it doesn’t create a P tag around the form. (If you must make this MI an inline object, then use the CrowBar Action instead of the Markup Item, so it will properly remove the surrounding P tag.)
</form>
With just this code pasted into your page in the proper place, you should have a third (working) form for searching the page. I didn’t see any form nesting or overlap in the page code, it looked as though it should work properly. I suspect that your issues are cosmetic, and cleaning up the HTML will allow the CSS to work as you expect.
On Dec 31, 2013, at 1:07 PM, Roy Gardiner wrote:
Here’s a page with two forms and the Site Search html code within a Markup Item:
http://test.advancedbarefoot.com/searchtest2.php
