Hi everyone. I was using FP5.0.2 on my iMac running 10.4.9 which then died. I’m now using a Macbook pro running 10.6.4. I can’t open any of my sites to edit them. When I double click on the icon in Finder, it acts like it’s about to load, but does nothing, or if FP is closed, it opens it, but not the file. When I’m in FP and try to open the files, they are ‘greyed out’, except for a very early version, probably created in FP Express 2 or 3. Any suggestions would be extremely gratefully received.
Jack
It’s possible it’s just taking a while to open the files though it sounds a little like they might be corrupt. Do you have any backups? Was it your last machine’s hard disk that died?
Jack
It was the power supply (I hope) that failed on my iMac. The files I¹m
using are back-up files/copies of the original, and to all intents they
appear to be fine, in that they appear okay in the Finder, and I can get
info¹ okay, and I see small representations of them in proview. It¹s just FP
that won¹t see¹ them.
Kind Regards
Anne & Jack Barnard
Rose Cottage Plants
Tel: 01992 573 775
Fax: 01992 56 11 98
E-mail: email@hidden
Web: http://www.rosecottageplants.co.uk
Reply-To: email@hidden
Date: Fri, 12 Nov 2010 12:20:54 +0000
To: email@hidden
Subject: Re: [Pro] FP5.4.3 Pro & Snow Leopard
Hi Jack,
Jack
Open it up, drag a Freeway file onto it and make sure the following values are entered into the Type and Creator fileds:
Type: LS3D
Creator: WAY
If they aren’t then add them and see if they open then. If not, could you send the smallest one over to our support team (support[a]softpress.com) and they’ll take a look for you.
Many thanks,
On 12 Nov 2010, at 13:10, Jack Barnard wrote:
Hi Joe,
Thanks for responding.
It was the power supply (I hope) that failed on my iMac. The files I’m
appear to be fine, in that they appear okay in the Finder, and I can ‘get
info’ okay, and I see small representations of them in proview. It’s just FP
that won’t ‘see’ them.
Kind Regards
Anne & Jack Barnard
Rose Cottage Plants
Tel: 01992 573 775
Fax: 01992 56 11 98
To: email@hidden
Hi Jack,
Jack
