Hello is Freeway 5.6.5 compatible with PHP 7.1?
That’s a voice from the past …
… but compatible … doing what exactly?
Hi Richard
I will need to rebuild the site from scratch but for now would like this to work using PHP 7.1 in MacOS Sierra 10.12.6. I have five forms that need to continue to function on the site.
Update: I have just done test with my ISP and so far, no it’s not compatible. PHP 7.1 breaks the form pages.
Tony
Okay, so you need to update to at least 6, in order to get the newer PHP bits in the Send Form Action. Tim and I have not touched the PHP Feedback Form Action in maybe ten years, so that would be a harder lift. I seriously recommend you buy a new license for Freeway 7, and consider it an investment in the further life of the company. You’ve no doubt gotten a lot of miles out of 5.6.5 by now.
On Aug 10, 2017, at 5:33 PM, Tony email@hidden wrote:
Hi Richard
Tony
Thank you for your help Richard and Walter
Appreciated
