[Pro] Freeway 5.6/6/7
I already have version 5.6.5 and version 6.1.2 running under OSX 10.6.8 - can I also have version 7 too?
It would appear that v5 and v6 happily share ‘Showcase’ 1.1.5, how about Freeway 7xxx?
Wild Cottage
Yes you can but you will get an error message about some actions that are not compatible with both versions (they share the same actions folder) - doesn’t stop it working but does give a warning on launch.
No issue with Showcase as it is a standalone app anyway.
David - many thanks.
I see that you’re using 6 & 7, I still need 5 for some legacy sites.
Wild Cottage
… so KEEP it because Version 5+ is running without any kind of problems. This is just because 5 is using a separate Actions folder, while 6+7 is sharing the same.
I have (for the same reason as you) running all three.
Many thanks Thomas!
Wild Cottage
