OK here are a couple of ideas:
First just so you feel good about Snow Leopard you may want to try the following:
With the MacBook Pro plugged into power start up holding the T key.
Connect a FireWire cable between Mac Pro and MacBook Pro.
Restart or startup the MacPro and hold the Option Key until you see the MacBook Pro HD. Choose the MacBook Pro HD and finish booting. Now try Freeway Pro.
Note: wired keyboards and mice plugged into the MacPro are best for this test.
Now that you know your Mac Pro’s CPU/RAM loves Freeway just as much as the MacBook Pro try this next.
Download Cocktail and really clear your caches.
http://www.apple.com/downloads/macosx/system_disk_utilities/cocktail_maintain.html
Then if you have it boot on DiskWarrior DVD and repair the MacPro HD. Some flavors of MacPro do not boot on last version of DiskWarrior although I do always recommend the latest version whenever possible.
As always make sure you have a current Time Machine or Carbon Copy Cloner or Super Duper backup before taking any drastic action. And one other and easy item to do is start Disk Utility from Utilities folder and “Repair Permissions” on your boot HD.
Dale Josephson
Dale Josephson Consulting
Apple Developer & Support
On Jun 4, 2011, at Saturday2:18 PM, Christopher Benz wrote:
Ok, so here’s the latest chapter in the saga.
I actually have a MacBook Pro and a MacPro both running 10.6.7 system and both attempting to run Freeway 5.5.7.
Freeway works fine on the MacBook Pro but hasn’t yet been able to startup at all on the MacPro.
I’ve compared font lists on both machines and deleted anything on the MacPro that isn’t in Font Book on the MacBook Pro. Still, Freeway refuses to start.
Does anyone have any clues about my next step? I’m running out of ideas!
My specs are:
2x2.8 GHz Quad-Core Intel Xeon
RAM: 10 GB 800 MHz DDR2 FB-DIMM
Hard Drive has 135GB free.
Freeway ran absolutely fine until my upgrade on this machine to Snow Leopard.
