[Pro] Freeway Pro 4
Yeah, yeah. I’m about a thousand years behind.
Running Freeway 4 on a MacBook Pro, with 10.12.6 as the OS.
Surprisingly, Freeway runs! I’m only using it for my website. No client work on it these days.
I was updating my website for 2018 today, and once I got everything done, I published it & went to upload it. Every time, Freeway spontaneously quits when I hit upload. I’ve restarted. I’ve gone to my web hosting service. Nothing seems to be showing.
I’m guessing the answer is I need to update, but I’m just wanting to do this one thing, so thought I’d check here to see if anyone had an idea.
thanks,
Phil
If Freeway publishes everything to your site folder okay and it’s just uploading that’s the problem grab yourself a copy of cyberduck and upload it manually.
All the best
Gordon
thanks,
Phil
OTOH, if it’s actually crashing upon publish, you may have a problem with a corrupt font or image. I’m not 100% sure “I published it & went to upload it” means you did them separately or it’s just the upload site step all in one.
For uploading, I like Transmit, but I’m sure Cyberduckie is fine.
