[Pro] Freeway Pro 6.0.6 Preview?
Why is the Preview mode in FWP 6 significantly different, in terms of color, than previewing the same page in Safari, Firefox, or Chrome?
Is that a bug or do I have something set wrong?
What might be nice is to take two screenshots - one of the FWP preview and
one of the Browser view, then provide links so the rest of us can better
visualize your problem.
Good idea. So that would indicate that you are not seeing any difference, correct?
correct?
True, I’m not having any color issues, though I only pay attention to how
things look in my browsers. I just want to see if I can figure what you’re
on about before I tell you to ignore it :slight_smile:
Color is relative – nobody sees it exactly the same way. I am lucky in
that I have excellent color acuity, but I’m not seeing anything that rubs
me wrong… There can be several explanations why you are not seeing color
the way you are expecting to, so what I’m asking for is a baseline
understanding of how you see the issue.
If you want to check your own visual color acuity try this fun test:
http://xritephoto.com/ph_toolframe.aspx?action=coloriq
