[Pro] Freeway Pro 6 and 7 on same computer?
Are there any issues in running Freeway Pro 6 and Freeway Pro 7 on the same computer?
There is the basic problem, that both versions share the same action-folder. Thus spoken, it may happen, that actions in 6 work fine - however break in 7 and vice versa.
I am currently running 5.5, 6 and 7 on the same machine, cause I still have projects for each version and don’t see any reason for “upgrading” them.
So if you plan to upgrade to 7, do it preferably for new projects rather migrating existing files from 6 to 7 (at least not after a successful testing of the actions in use in 7).
Thanks Thomas. Is there a list of actions any where that are affected if one has Freeway Pro 5.5, 6 and 7 all in use on the same computer?
