I know that several of softpress’s employees participate in this forum, for which I am very grateful, so I thought it would be helpful to start a thread for Freeway Pro feature requests.
Much wider “New title:” data entry space in Retitle page action.
How wide do you want it? I can make these as wide as you like (within reason). Give me a rough indication (ideally in pixels) and I’ll update the Action for you.
My little feature request would be to have some Find Page method for all those pages in the left column in FRW, to have it marked (darkened?!) in some way when found.
As it is now, I have a hart time to find a specific page among the increasing number of them on our FRW-site.
/ Omar
::: Communication to improve civilisation :::
s_ip
Hope you don’t mind me jumping in. I was considering asking the same question as ravenmaniac, but in reference to the Meta Plus action.
How about 70 characters, as this seems to be a ‘standard’ maximum for a page title?
Paul
Thanks for your response. It looks like it’s currently about 120 pixels wide. If that’s the case, what do you think about making it 360 pixels wide?
Hi Paul,
I’ve updated the Action to show up to 41 characters (300 pixels) at a time. Seventy characters makes for an awfully long text input. which I can do but I may have to do this with a pop open window. Try version 1.4 (http://www.freewayactions.com/product.php?id=014) and see if that helps.
Okay, I figured this out. For some reason, trying to install the action by double-clicking didn’t work, so I basically drag and dropped the new action over the existing one in the Freeway Pro application support folder.
To do this in Lion you have to use the Go menu in Finder and hold down the Option (Alt) key, the Library becomes visible and choosable. This tip was from Paul Bradforth.
Thanks Tim
41 characters is a big improvement.
Paul
On 08/02/2012, at 5:37 AM, Tim Plumb wrote:
Hi Paul,
I wants loads of things but what would be ace - to have Softpress servers dedicated to sites that can be hosted on there with full blown CMS… I keep my eye on Adobe’s Muse purely for this reason. Its the most requested request I get when pricing jobs. I know theres loads of stuff out there but nothing totally dedicated to Freeway Pro - just be very convenient!
