Hi there,
This may be a stupid question, but how do I create a simple table in freeway pro. I tried the table feature on top, but this tables seem very very simple with limited functionality.
Please look at this website table, http://www.uswitch.com/credit-cards/credit-card-uk/
The table on the above site has a green colour on top and is very simple. When I try to add colour to the top row of the freeway table, the whole table is coloured. Can I simply import ms word file table into my freeway page? I am planning to have some text and images inserted in the table, so drawing separate graphic boxes is not the way to go I guess.
Any comments
cheers
You can style individual cells, rows add graphics all to a ‘simple’ FW created table.
If you want to colour a row you have to just select that row
Hover your cursor over the left hand edge of a row until it turns into an arrow and then click - your row is now selected.
Click on the first ‘Cell’ tab in the table inspector and add your colour
Thank you very much Dave
I didn’t notice that the colour inspector was closed.
One more thing I am worried about. I have the text in the cells in red colour when the mouse is over the text, how to set an action to turn green? I mean the hoover.
cheers
Styling text with a rollover is the same whether it is within a table or not.
Do you wish this text to be a link to somewhere else or just change colour when hovered?
Thank you Dave, I am ok with this actions now.
