Hi Rakeljuice
As there seems to be some confusion for you i some areas, I thought an
overal explanation might help:
Yes-you will need the actions that Max makes to build sites that use
WebYep in Freeway. Please let me explain.
If you are going to do everything to change the website yourself, then
you do not need webyep or max’s actions. You can do everything in
Freeway using Freeway to make changes and uploading via ftp.
If someone ele will be using the site (who does not know how to edit a
web page using an FTP program) then WebYep is a very good solution.
Freeway Pro is very very good indeed. It uses what are called ‘actions’
to enable websites to do different things. It comes with many actions
already installed, and others are available as ‘add-ons’-you can get
some add-ons (quite a lot in fact) for free. Others you buy. Max makes
some that enable WebYep to be used. Max is a very nice and helpful man
and his actions are available from his website (his webyep actions are
bought, not free, but the price is very good, and they all come in one
set). There is a place where almost all Freeway actions are held,
www.actionsforge.com. You can find links to download lots of things
there (including a link to Max’s website to buy his actions for WebYep.)
Whenever I have emailed Max he has always been amazingly helpful and
kind. Also the staff at Softpress (who make Freeway) are fantastically
helpful.
Will your webyep site be on a Windows server or a Linux server? If
windows then there can be issues as Webyep and Windows servers do not
live together happily sometimes. I am running WebYep on a Windows server
but sometimes things had to be adjusted on the server. I may be able to
help if you have an issue with this.
WebYep does not currently have a video upload facility. If you will
change the link to the video (rather than your client having to do it)
then there should be no problem.
To use the actions for webyep, first buy the action suite from Max.
Install them.
Build a page in Freeway. If you want any part of the page to be a webyep
item (that means that you or your client will use webyep to change the
content,) just apply the action to the item on the page in Freeway. Set
the various parameters in the actions palette in Freeway and you are done.
Sorry if you already knew some of this.
Martin
On 31/07/2011 15:09, rakeljuice wrote:
Thanks for your quick answer.
Im reading more, and searching http://danjasker.com and http://www.max-izzat.co.uk but I have not clear what they do exactly. People says in forum that is so easy with Max actions, but what is this? I think I cant catch the sense because of my english… Is any easy explanation about that, please? Im going to buy freeway and webyep tomorrow, but Im not sure if I need to buy max Action for webyep or not…
Concerning videos, my idea is: I have 4 videos, and everyweek I want to show one of them in the main page. The fith week Ill show the 1st video agin. So I wolud like to have them in my website uploaded and just need to change a link. Is it possible?
Thanks again. Rakeljuice
dynamo mailing list
dynamo mailing list
