billyk
October 6, 2015, 1:59pm
1
Upgraded to Freeway 7.1.1 and already getting a headache.
Can anyone tell me why I’m getting a messed up result on iPhone?
You won’t see it on your desktop, you have to look on an actual iphone.
Everything is jammed to the left on the screen.
Please help.
Billy
http://www.smartytest.com/evfarm/christmastrees.php
Your div #text , #text2 and the div #headline have fixed widths larger than the phone width. Try making those 100% width.
David Owen { Freeway Friendly Web hosting and Domains }
http://www.ineedwebhosting.co.uk | http://www.PrintlineAdvertising.co.uk
Please help.
Billy
billyk
October 6, 2015, 2:30pm
3
Could you look at the home page, it is doing the same thing and I don’t have any fixed widths.
This wash’t happening until I upgraded to 7.1.1
Billy
Hmm - doubtful, whatsoever:
The Div in question is this SnowFlake which has a left position of 578px and you’d perhaps agree that this is off-screen on a mobile (max 480px) causing the page to side-scroll.
It’s all about positioning and width values. Unfortunately people meant this as bug - it isn’t at all.
Your page has width = device-width, minimum-scale = 0.25, maximum-scale = 1.60
Try making that…
Width - none
Height = none
and
initial-scale = 1.00, minimum-scale = 1.00, maximum-scale = 1.60
From the Inspector Palette > Mobile
Billy
billyk
October 6, 2015, 3:11pm
6
Dave, can you send me a screen grab of what you mean. I never touch these in the inspector.
Billy
You also appear to have set breakpoints at 40px and 35em - not sure if these are meant?
billyk
October 6, 2015, 5:29pm
8
My lowest breakpoint is 375. Where are you seeing that. Maybe it’s these Freeway Templates.
Ugh!
Billy
Theres an app for that
Omar_K_N
(Omar K N)
October 9, 2015, 7:15pm
10
What’s that app called?
Otherwise I’m using XScope, they have dimensions for different screen & devices.
with best regards,
Omar KN
Stockholm, Sweden
It is actually a Javascript Bookmarklet - get it at http://breakpointtester.com/
Or use my favourite…
Viewport Resizer - bookmarklet.
David Owen
List Options | FreewayTalk
Caleb_G1
(Caleb G)
October 9, 2015, 9:41pm
13
Or, if you are using Safari on El Cap, ⌥⌘R will bring you into the new responsive mode.
