I would like my page to be centered, but try as I may I’m missing something. I have the page alignment to “none” as I’m wanting to build an inline responsive site. I’ve fiddled with the float and align of various container items, but so far I’ve not found the right combination. Please someone tell me what I’m missing. Thank you!
If I could look at your FW7 file that would be great. This is a very large website and I’m working very hard to get the bones of my inline construction perfect before I start adding content. It would be a real pain to change it later!
I’m working with your file and I’m wondering if my problem is I want the two images (logo & banner) side by side. I’m setting their alignment to “baseline” so they align properly to one another, and I’ve set their parent div to center. It seems like this should work, but it isn’t. Is the only workaround for me to join the two images into one?
Ahhh a background image! That’s how you did that! I was puzzled. Regarding the two graphics into one… Yes, you’re the one that gave me the idea. It doesn’t seem like it should be necessary, but maybe it is. I’m trying to build inline, but my mind is still thinking drag & drop simplicity!
just one question regarding your example: your Hamburger icon is centered nicely. That’s because your menu is aligned centerwise. I want to show my Hamburger icon also aligned center when the browser window becomes narrower, but the navigation should be kept aligned right.
Any idea how to set this up? I think the icon align setting is related at the navbar?
Thanx
Andries
On 15 Sep 2014, 10:06 pm, DeltaDave wrote:
Here is a quick example though I would probably incorporate the PCA logo into the header image
