I noticed that when I create a new page with a longer title, the file name is shortened in the general page setting file. For example if I have a longer text - mywebsitedesign.html, it is shortened to mywebdes.html
I can manually change it, but do I require this? Is it a problem with something if I don’t change the longer text?
That happens when Freeway just suggests a page name based off of your page title. It is always best practice to change the subpage names to make sense. So instead of “contactusbecauseyouthinkwerecool.html” could just be changed to “contact.html”.
However, make sure to leave the home page to always be index.html or else your site won’t load but for subpages you can go ahead and change them.
You can also change the Max. filename length to default to something longer in File>Document Setup>Output and change it to a greater number of characters
I guess I have to do it manually I can not find the option you recommended.
You will need to go back through your pages and manually change the
automatically-generated filenames. This setting will only affect new
pages made after you change it.
If you want to reset the default for all future documents you create,
just make this setting change while no documents are open in Freeway.
Anything you find in the Document Setup dialog while there is no
document open is something that you can set as a global default.
Again, this will only change the future, not the past, and changing
the setting within a document will only alter that document.
On Sep 10, 2011, at 11:40 AM, DeltaDave wrote:
Select that and then in that Pane there is the option to change the
number of characters in Max. Filename length
