I am building a new site and the gif text looks horrible. I have copied a gif text box from a previous site and pasted it into the new site. It was fine in the original site but now looks pants.
The original size was 3117 but the pasted copied box is 638!
All of the gif settings match – what am I doing wrong?
When you say “GIF text” do you mean you’re using a Freeway graphic
box to set and generate brand new graphic text? Or do you mean you’re
importing and using a bitmap graphic that already exists?
Also, what exactly do you mean by ‘looks horrible’? Is there an
example online that we can see? It is hard to troubleshoot otherwise!
Sorry…
k
(BTW, if you do mean text that you’re setting directly in Freeway in
a graphic box, it is better to call this stuff “graphic text” rather
than “GIF text”. It won’t necessarily be in GIF format when it is
generated.)
Hi. Yes, I am drawing a graphic box and then inputing copy into that.
I am baffled because it has worked fine on every other site that I have created. Even importing graphic text from a previous site that looks great doesn’t work on this new site.
I haven’t uploaded the site (thank goodness) – so it’s difficult to show the problem. But the letterspacing is shot and the characters are bimapped.
I have just copied the offending graphic box from the new problem site and pasted it into a previous website… and lo and behold the graphic text looks great.
I haven’t uploaded the site (thank goodness) - so it’s difficult to
are bimapped.
Is the box layered in one site document and not in the other?
What background image or colour is behind the graphic box?
You could try setting the graphic box to be output as a PNG at
millions of colours. Does that solve the ‘bitmapped’ effect?
The letterspace problem is more worrying. That sounds like weird font
settings problems. Does this happen if you draw a brand new box
somewhere on an empty part of the page?
I opened a new Freeway file and pasted in the two graphic text boxes on the left. I copied these and pasted them into the problem file – shown on the right.
Layers, backgrounds, etc make no difference. It does seem that file is corrupted. Can that happen? Is there a work-around, I really, really don’t want to start again.
There appear to be no other problems with the file apart from the graphic text.
What happens if you choose a different font? Try one of the built-in TrueType fonts – Georgia, for example – and see if it still shows those problems. What you’re describing (and the fact that the PNG didn’t fix it) seems like maybe your font has lost track of its outline file, and is operating on the bitmap (screen) font only.
As I said this is the only site that has this problem.
I hate to step back from helping, but I think this is something the
official support folks might be best handling. It sounds weird.
But tell me one thing: if you make a new Freeway document and try
making a simple graphic box with text, does that work ok? If so, you
could copy/paste whole pages from the suspect document to a new one,
testing each time to see if the problem comes back.
