How can i get the go daddy script to work? I can go another route,but I rather be able to install the go daddy script. I am also using this with backdraft
Just to mix things up, some GoDaddy servers are standard Linux / cPANEL servers, nothing odd needed at all. You may want to try using the standard Send Form Action settings, as designed for normal servers, and see if that works. If not, maybe someone from Softpress can pipe up here, or someone who has wrestled with the bad old GD servers.
