Hi, Thanks for the help - Got the form to work with Godaddy
Next problem, I can never get a fail page? Even if I just press send - it will send a form - And goes to the success page - but weirdly the home link does not work???
Hi Justin,
Unlike the regular PHP processor the action creates the GoDaddy option doesn’t support an error page. This is a limitation of the installed GoDaddy script. You’ll see that when you select the GoDaddy option in the action palette the error page control dims as an indication that this field ins’t needed. If you’ve already set an error page then this will simply be ignored when using GoDaddy’s script.
Looking at the success page I can’t see a link wrapped around the Home text. Make sure that the updated page has been uploaded and that you can see the link in the source code. If you’ve uploaded a file with a link in it and you are still not seeing it work correctly then I suspect something between you and the page is cacheing the page. Try clearing the cache on your browser or simply change the name of the page in Freeway and upload again.
