Paul_Rowe
(Paul Rowe)
August 18, 2013, 9:47am
1
Can somebody please clarify the correct procedure to install the Google Analytics code issued by Google - I’m using Freeway Pro 6.1
Google discuss inserting the HTML code in their general advises but I note there is a Google Analytics Actions facility which appears to require ONLY the Google issued UA code.
Does the Freeway Action somehow aquire the HTML code from the UA number and insert it into the Site Folder ???
Would greatly appreciate some guidance.
Rgds
Paul Rowe
Use the action and then the action writes all the GA code in the correct place and adds in the UA# to make it specific to your site.
The GA code is the same for every site apart from the unique UA#
Paul_Rowe
(Paul Rowe)
August 18, 2013, 12:34pm
3
Greatly appreciate your feedback - thx very much.
Rgds
Paul
Article here
Google Analytics is an excellent way to analyze traffic to your site allowing you to determine the best path to a sales conversion, see the route your visitors are taking round your site, where they are visiting from, what platforms and browsers they...
Paul_Rowe
(Paul Rowe)
August 18, 2013, 12:52pm
5
Duly Noted - thx again Dave
