[Pro] Google Analytics
Help needed with the Analytics
I have installed analytics on my page www.hafniaservice.dk but no tracking occur, and when I test the site in http://checkwebsite.erigami.com it comes up with two errors the Javascript file is not downloaded and the account variable is not found.
Any suggestions how to fix it? I used the build in tool to implement it.
Best regard
Per
You can use the google analytics page action to implement it. Then you just fill in you GA code and it takes care of itself.
I think that’s how they did it. Per, how long ago did you add the Action and upload? It takes 24 hours before tracking will start.
Thnx for the answers. Yes I used the action to put in in. It works fine now, but its a little odd as the site was changed and it was put in several weeks ago. But no matter what it works, and by your answers I got confirmed that it was the right way to do it.
Best Regard
Per
