[Pro] Google Maps and FWP 6.0?
How can you get the Marker Text on Google Maps in FWP 6.0 to display on multiple lines, like this:
Company Name
Address
City, State, Zip
Phone Number
Well I did it by using
and
in the Actions palette, but there’s probably a better way.
Sorry that was 5.5 not 6.
You can use the Google Maps Marker Action to do this. Just draw an HTML item (layer), add the text you want, apply the Google Maps Marker Action, select the map item in the Action palette, and choose your settings.
Company Name
Address
City, State, Zip
Phone Number
I was using the Google Maps Marker Action, but it doesn’t seem to work as well with FWP 6. I’ll need to fiddle around with it more to see if it was something I did or truly a compatibility issue.
Joe, I stand corrected. It works great! I especially like the new multiple marker feature. I have a project I’m working on right now where I can really use that feature. Thanks!
