Can anyone tell me where I place the Google Translate code snippet in freeway - cant seem to get it working?
I’d also like to know this.
Hi DillyDog
I have since figured this out - quite easy really.
Just copy the snippet of code from here
http://translate.google.com/translate_tools
check out the options available that will alter the code you will require and paste it into an html markup box (insert - markupitem) and position where you want it to appear on your Freeway page.
You will need to upload you page to your server as you will not see the results in Preview or Preview in Browser. You may need to resize the markup item box to suit your Google Translate box.
Regards
