[Pro] Graphic Actions
I am new to Freeway having just downloaded the trial today.
I can’t find the Graphics Actions - how do I access them (or are they absent from the trial?)
Thank in advance for you help
Richard Linter
actionsdev mailing list
Freeway’s trial versions are 100% the same as the paid versions, with
a time-bomb attached. Everything that’s in the paid version is there
in the trial. What you may need to experiment with is this basic fact
about Freeway:
Everything is contextual.
What you see in the Inspectors and menus is entirely dependent on what
you have selected in the design view at the moment.
So if you click on a graphic box and then look in the Item / Actions
menu, you will see the Actions that can apply to that element
highlighted in the list. If you want to apply a Page Action, then you
need to make sure that nothing is selected. Otherwise, while you will
be able to apply an Action to the page using the Page / Page Actions
menu, you will not see that Action’s interface in the Actions palette.
Richard Linter
Is there a Freeway action that will allow me to rotate a series of 3 images every 5 or so seconds? Maybe with a transitional effect. :slight_smile:
I can’t seem to locate anything available in the “stock” set.
Thanks!
Got it!
Thanks, Walter.
