[Pro] Graphic Item nav bar issue
Hello,
Im building a web site using Freeway 5 Pro. My navigation bar is constructed out of graphic items that have an up state, a rollover state and a down state and I use the rollover action for each. They all work great except one thing. I have 7 buttons total. The first 4, rectangle shape, each of different width value and same hight lined horizontally, works great. But the 5th and 6th buttons have a radius curve (for style) that fits them together, but still each are separate buttons for different use. The are overlapped to get them to fit together. My dilemma is that Freeway only recognizes items as a 4 point box or rectangle, even when I make a path item for the radius. So what happens is when the right side of the 5th button is clicked it actually clicks the 6th button because freeway is recognizing it as a box not a item with a curve.
How do I get around this? Can you help me with this? Have any suggestions?
Any advise is most appreciated. Thank you!!
