Hi all,
I have a graphic (OceanView) that I can’t get perfectly lined up with picture.
Is there a different way to accomplish this and get it exactly to the edge of picture?
Thanks for any help in advance.
Emilio
barbados-seawinds.com
Not quite sure what you mean. Can you tell us a bit more?
I think he means the banner that says OceanView on the beach image.
It looks fine to me.
Me too - if you are really picky there is a very small gap - but hey, this is the Web.
If you want it pixel perfect than add the banner in your Graphics program to the actual image.
Then import the image into an html container and add the rounded corners and shadow using the CSS3 Corners and CSS3 Shadow actions.
http://deltadesign.co/FW7Test//silversands.html
Thank you all.
I guess I am being picky.
I thought there may be a way of accomplish this in Freeway.
I like what you did Dave. I am not good on graphic programs but I will try.
Thanks to all again!
FW7, not in Canada … pity, eh
Get the image at http://deltadesign.co/FW7Test//Resources/silversands.png
