Hi Tom
The answer is yep and no… it uses a lot of jQuery so you do need to get your hands dirty a little bit but apart from that it should be fine to construct… I will make an example and send it to you
all the best max
And remember, if you use jQuery, you will need to set the flag on
jQuery that allows it to work alongside Prototype.js, or else give up
using any of the Freeway FX Actions or Protaculous or Carousel.
On Nov 10, 2009, at 10:30 AM, Tom Sommerseth wrote:
Hi Max!
Totally out of my comfort zone hehe. With the coding part
