Hello,
I am creating a site with a page full of thumbnail pictures with a roll-over and image target action on it. They and the enlarged pictures are in a css layer. The thumbnails are grouped and the target images are grouped to. The target pictures are a mix of landscape and portrait orientation. In preview and browsers the the roll-over and target work well but the group of large image targets is shown in a grey box which is the surface of all stacked images… rebuild 3 times, always the same effect. No sign in code that the box should be grey… anyone an explication or solution?
Thanks.
Cant you post a link to the online page in question and we can have a look.
here is the link:
http://agent1266.c-wh.org
thanks
Item23 - dewoni3t.jpeg appears to be set to show all the time
If you look in the Page/Site pane Left side of your screen - normally headed up Site and toggle to Page - you can choose to display all items on the page.
Select item23 from the list and delete it
Thank you David
I’ll try that
Agent1266
