Hi there
I’m working on rebuilding an old website using a different technique but I can’t get my graphics to line up properly.
I’ve created a jpeg background graphic which measures 770x50 pixels. The white area in the centre of this for the page is 752 pixels wide.
I have a header graphic for the page which measures 752x100 pixels. When I insert this graphic on the page everything seems to line up perfectly. However when I preview or publish the page the graphic is half a pixel too far to the left. Now I know half pixels shouldn’t be possible in website work so I’m at a loss as to how I can fix this. I’ve tried inserting the graphic as a pass-through, png and jpeg. I’ve tried layering on and off and I’ve even put it in a table cell and the result is always the same.
You can see a test page at Welcome to GordonLow.net | Audio, Design and Internet projects
Looking at the source code I see that the size of the graphic varies but the result is always exactly the same - half a pixel too far to the left.
I’m really hoping someone can work out why what I thought would be a simple task is going wrong and how I can fix it.
Many thanks
Gordon
