I use Seagate Momentus mechanisms in my external usb drives. They have been
wonderful performers and I will keep using that drive. However, I’ve
noticed they have vibration issues - on some surfaces more than others.
This can be annoying over time, so what I did was go to the hardware store
and purchased some of those self-adhesive felt pads for the underside of
furniture, then cut them smaller and fit them under the drive enclosures so
they sit on the desk or table or whatever with a little cushion. There’s
one idea for you to experiment with.
My wireless keyboard doesn’t vibrate, but my “desk” is uneven and the kb
constantly “tips” back and forth - so I have a small hand-towel folded
underneath. This slightly raises the kb, but absolutely dampens it on my
work surface.
The problem with a laptop is the bottom gets warm, even hot. While a towel
would dampen vibration, it’s not very good a dispersing heat – so
experiment.
The only concern I would have with vibration of the internal drive is worry
whether I had seated it correctly when I installed it. Rule that out, then
any vibration issues become “normal”. It’s a good drive - faster, consumes
less power.
On Sun, Feb 24, 2013 at 6:34 AM, RavenManiac email@hidden wrote:
I just upgraded the hard drive in my son’s MacBook 6,1 from the stock
250GB Toshiba 5400 RPM drive to a Seagate Momentus XT 750 7200 RPM Hybrid
Drive. The difference in performance is amazing, but his MacBook now has a
slight vibration, which resonates throughout the laptop. It’s not extreme,
but I never recall this with his stock drive.
Is this normal or could the drive be defective?
