Looks like my upgrade to Freeway 6 and Protaculous 2 has bitten me in the butt. I was cautious with this changeover and first read Walter’s posts about clearing the cache beforehand. But once I finally pasted the old Protac function body code into the DOM Loaded Observer and tried to upload my revised v5.6.4 document, I got a Javascript error saying “head has no properties.” The code it singled out is part of this bloc:
if(!script){
script = head.fwAdd(‘script’, true); <<<<<SINGLED OUT FOR ERROR
script.fwAddRawOpt(“);
head.fwAddRawOpt(”);
I’m hoping I’ve copied every character right here (FW’s error window has it pretty small and won’t allow me to copy it), but I can see the offending line is correct. Any suggestions out there?
If you can tell me how to copy all the error window code, I’ll gladly paste it all here if it will help, but I have no clue.
If you have applied the PHP Make Insert Page Action to the same page, that could explain this. Otherwise, I am not sure how it could come about.
Could you please send me an example file that shows this issue. It should be just one page – with the Action applied.
Open your failing document, File/Save As… and rename it. Select all pages except the one example page in the left-hand list and delete them. Save. Send the file to me off-list (if you’re an e-mail user, just control-click on my name and choose Reply to sender from the options; if you’re a Web user, click on my name above this post to see various contact options).
On Sep 1, 2013, at 5:26 PM, Joe wrote:
I’ve added a screen shot of the Protaculous 2 error panel (it’s a long one) at:
