In Freeway Pro 5, I have a page with a height of 1100px. However, in Preview mode, and even when I publish and look at my my site in the browser, the website “stops” after the last object and I can’t scroll to the full height of the site.
Web browsers will only ever render a page down to the
lowest-positioned object, regardless of how tall the page is in
Freeway. If you want more height you’ll need to add something further
down. Anything that produces actual content will do. An unfilled
graphic box, for example - that won’t be visible but will make the
browser scrll down that far. Or some HTML text. Don’t use just a
regular space though; browsers ignore that. Instead, use an
option-space character. That’s the ‘non-breaking-space’ character,
and that does get rendered… and it is still invisible.
Even though your page is 1100px high if there are no objects on the page beyond a certain point then there will be nothing to tell the browser to go on.
If you want a height of 1100px then you need content up to that point.
I see, however I have a page with a height of 918px. The last object is at around 820px, and the browser scrolls to the whole 918px. Who do you explain that?
