[Pro] Help - a slightly unusual problem...
All of your replies are here, not sure why you’re not seeing them. The Freeway document is just the assembly instructions. If you want to get the entire site, all assets, everything, you need to export an Archive of the site. Are you able to mount the hard drive from your old laptop on the new one? Read up on Apple’s “Target Disk Mode” and get the appropriate cable to connect the two. You may be able to gather all the assets and get everything working again. If you can open the old site from your new laptop, you should be able to save it as an Archive, which will collect all the assets used within it and then re-link them so that Freeway will stop looking for them at the old locations.
On May 13, 2018, at 6:06 PM, Heather Hughes via freewaytalk email@hidden wrote:
Trying to reply to this again, seems to be impossible to reply…
FWIW, Walter, I’m only seeing your last reply in this thread on the website.
