Hi all,
I was wondering if anyone could help me install this slider as I have been having some problems.
Thanks very much,
Seb
Hi all,
Thanks very much,
Seb
anyone have any idea?
Seb
I’ve managed to install it and it is working fine, however when trying to style it with a custom stylesheet, it starts behaving very strangely.
Here is the link, if anyone would like to look: http://www.sct-photography.co.uk/workflow2/nivo.html
I’ve managed to install it and it is working fine…
Doesn’t look fine to me.
Hence the latter part of my post…
First thing I would do is put in the full path to your images - you have: /workflow2/newslide1/images/loading.gif
Change that to http://www.sct-photography.co.uk/workflow2/newslide1/images/loading.gif
and the same for the others ie full path and not just relative because the correct relative path is actually /images/loading.gif
So no matter what page or in which folder the path will be correct.
I was also going to tell you to use jpegs instead of gifs for continuous tone images but I reckon you know that already.
Hi Dave,
Thanks for your reply.
Now I have a couple of minutes to actually sort this, I can explain things a bit further.
Basically, I have two stylesheets. One is the default one with no styling and the second is one that I have made adjustments to.
It works fine linking to the default one and I get nice pictures with effects however, when linking to the second stylesheet (default.css) it starts looking like my above link.
Seb
