t50ufo1
(t50ufo)
November 9, 2016, 8:52pm
#1
Need some help - linking to the big image ok in this test page but can not get zoom function to work.
I have added the class magiczoom to the small image
and to the class magiczoom to the large image
have added page markup thus:
The uploaded folder magiczoom in in the subfolder mzoom
Regards
Trevor
www.trevormckay.co.uk/mzoom
t50ufo1
(t50ufo)
November 10, 2016, 9:55am
#3
Thanks Dave.
Can’t get head round where the files and links should be.
At minute the js and ccs magic zoom files are in the root folder (mzoom) in a folder called magic zoom
the paths in the markup are this:
I have also tried the full path for each, i.e.:
http://www.trevormckay.co.uk/mzoom/magiczoom/magiczoom.js
current page here:
can you see where I am going wrong?
T
t50ufo1
(t50ufo)
November 10, 2016, 12:48pm
#4
Update:
I got going Dave after a bit of trial and error!
One other thing was: class name
I had magiczoom should be MagicZoom
Can you tell me where I should place the example code for an internal zoom position as on this example page:
for say: Internal Zoom?
Looks like you found it.
Or you can set it Globally (rather than an image by image basis) using
<script>
var mzOptions = {
zoomPosition: 'inner'
</script>
Add that in before End Body should do it.
t50ufo1
(t50ufo)
November 11, 2016, 8:37am
#6
Thanks David
yes after a lot of trials finally got it last night.
Global setting will be great and save adding to each image.
As always, thank you for your time and help here on the forum.
Trevor
