Erik
(Erik)
October 27, 2015, 3:46pm
1
Hi guys,
Need help here,
uploaded website for a client and somehow the mobile menu is not working ok on every pages?
for example here it works:
http://www.atelier-audio.com/English/events.html
here not:
http://www.atelier-audio.com/English/about.html
Also,
I added the simple button action, tested it local, everything worked fine,
now after moving to a different server (and installed simple buttons) the colors stays grey?
Help is much appreciated
Erik
The purpose of this topic is to provide information about the migration from FreewayTalk and Groups io to Discourse and the differences in Discourse, as well as a place to discuss the good or bad of the migration. For those previously subscribing...
Reading time: 2 mins 🕑
Likes: 1 ❤
Looks like a javascript error on the about.html page
To do with WOW animate I think.
Take that off and see how it goes.
Likes: 1 ❤
Uncaught ReferenceError: WOW is not defined
var wow = new WOW( { boxClass: 'wow', animateClass: 'animated', offset: 100 } ); wow.init();
Likes: 1 ❤
Erik
(Erik)
October 27, 2015, 8:52pm
4
Hi Dave, thanks
But strange thing is that I only have WOW slider element on a few pages and not on the pages above
can you explain that?
Likes: 1 ❤
Have you added WOW code to a Master?
Doesn’t get onto a page on its own.
Erik
(Erik)
October 28, 2015, 11:44am
6
Somehow, the WOW code is connected to the js menu,
if I create a new page and delete the CSS menu the WOW code is gone!
Abracadrabra
Likes: 1 ❤
Erik
(Erik)
October 28, 2015, 3:15pm
7
Hi Dave or somebody else,
After 2 days struggling still no solution, help please!!
On my test server here:
http://www.test.atelier-audio.com/welcome.html
I get an error :
ReferenceError: Can’t find variable: WOW
here same website not:
http://www.test.atelier-audio.com/English/events.html
First I thought it had to do with a WOW slider i had implemented.
I delete all wow elements and add Exhibio
But I see this code also on different sites so nothing to do with WOW slider I guess.
Anyway who can tell me what goes wrong here and who to fix
The same website is also running ok on my own testserver:
http://atelier.graphicid.nl/welcome.html
Here everything works fine.
Has this something to do with the ftp server maybe
help much appreciated, thx
Erik
Likes: 1 ❤
Rather than WOW slider have you added anything to do with WOW animate
Likes: 1 ❤
Erik
(Erik)
October 28, 2015, 10:57pm
9
transition fx action and simple button action
is that in the same category?
But how do you explain that on one server it works fine and on the other not?
Likes: 1 ❤
I thought it was 2 different pages - not different servers?
Do you have links to the same page on different servers we can compare?
I am not familiar with the Simple Buttons action - is that one of Tim’s, it may use some WOW stuff!
Erik
(Erik)
October 29, 2015, 8:49am
11
Hi Dave,
Yes these are Tim’s actions;
http://www.test.atelier-audio.com/English/about.html
http://atelier.graphicid.nl/English/about.html
Likes: 1 ❤
How did you publish, FTP or Freeway’s machinery - and both the same method?
The one still misses the wow.min.js for whatever reason! Maybe it’s even a host/server-side thing?
Have as well a DETAILED look into your FONT-sets and REMOVE all final semicolon on each Google Fonts that you created. You have throughout the page many invalid CSS declarations.
Likes: 1 ❤
waltd
(Walter Davis)
October 29, 2015, 12:55pm
13
Servers categorically cannot affect JavaScript (not normal Apache servers, anyway – Node.js is another matter entirely). The only thing that could mess between simple button and transition fx is if you also had unrelated jQuery in the same page. jQuery and Prototype (which is what Transition FX is based on) do not get along well.
Erik
(Erik)
October 30, 2015, 9:47am
14
Thx Thomas/ Waltd,
I go check these suggestions!
Erik
Likes: 1 ❤
Erik
(Erik)
October 30, 2015, 10:32am
15
Hi Thomas/ Waltd
I checked the wow.min.js but it was on the server?
Now I did the following;
removed the files from both 2 different test servers,
Upload with Freeway first to my test server;
Then the same file to client testserver
http://test.atelier-audio.com
Exactly the same file
Now everything works fine except the button style (simple buttons)
they are fine on my server (red) but different on my client server (grey)
Any idea what causes this?
Erik
Likes: 1 ❤
In the grey button example, there is missing the css which should be auto-generated by the button action (I suppose cause I don’t know the action at all) and print it into the head part. This all is pretty weird, cause I can’t tell you why the action kinda fails and am close to recommend giving Tim a quick note on this.
Likes: 1 ❤
Tim3
(Tim)
October 30, 2015, 11:39am
17
Hi Erik,
Apologies for getting to this thread late in the day. I’ve only just read through it this morning.
Your client’s server (unlike your test one) is processing Server Side Includes (SSIs) and sees part of the CSS styles in the head as a call to one of these includes. If you look at the source code for the failing page you’ll see an error in there;
[an error occurred while processing this directive]
The code that is doing this is;
<!--#item3
I’ve updated the Action so that it now writes these styles out in a more readable form (line for line) regardless of how you’ve set the code output in the document setup. The CSS styles will be slightly less compressed than they are at present but it will ensure that you don’t encounter this issue again.
I’ll send the updated version of the Action (version 1.6) to you directly now.
http://atelier.graphicid.nl http://atelier.graphicid.nl/
http://test.atelier-audio.com http://test.atelier-audio.com/
FreewayStyle.com - Freeway templates and parts to download, use and explore - http://www.freewaystyle.com
Erik
(Erik)
October 30, 2015, 1:58pm
18
@Tim ,
Thanks for helping me with this issue,
I’m gonna download the updated action and try it!
@Thomas ,
as always thank you very much for helping me also!
Erik
Likes: 1 ❤
Erik
(Erik)
October 30, 2015, 2:19pm
19
Everything fine now!!
thx again
Likes: 1 ❤
