Hi Erik -
It is always helpful to publish a link to your site, the code tells us much.
I get it, header section (plus content) body section (plus content) footer
But where do “border section” and “background section” come in??
If you use the Opacity setting in the Inspector, it sets the opacity of
everything in your item, not just it’s background (Note to Softpress - this
is a poorly implemented interface design problem, but you knew that already
and have your best minds working on it as we speak - right?)
A better background opacity solution is RGBA, but before we get that far
Erik, can you upload your site to a test location where we can look at the
code and evaluate the problem?
On Tue, Mar 5, 2013 at 5:47 AM, Erik email@hidden wrote:
Hi guys, need some help
At the moment I rebuild one of my sites, from basic layout to inline box
model in Freeway 6
I used 3 sections:
header section (with header content), bodysection (with body content) and
footersection (with footer content).
I placed a background image in the border section and give the page
(background section) a color and 75% opacity.
Now when I place content in the body content the stuff also gets the 75%
opacity, something I don’t want
Is there something I can do about this?
Thx
Erik
