Would you take a look at this page and help me figure out how to keep the orange "Online Giving’ graphic item to the right of the blue ‘Ways to Give’ html item? It looks great in Freeway’s Page View, but not in the Preview View:
I’ve inserted a graphic item inside an html item. So far so good. When I preview that, everything lines up correctly. But when I import the actual graphic (Online.jpg) into the graphic item box, it kicks out to where it is now (under as opposed to staying to the right).
I know I’m missing something, but can’t figure it out. Anybody see my mistake?
You’re right, it’s fiddly. . . I finally managed to get it to work, but I’m not exactly sure what the solution was - LOL!
One more unrelated question: How do you change the color of indented bullets to match your text? If you scroll to the bottom of the linked page, you’ll see what I mean:
You shouldn’t need this in 5.5 – Freeway hasn’t coded list items
incorrectly in quite a while. That Action was very important in
Freeway versions less than 3.5, I think. The key is to make sure that
any color effects you are adding to your text are added at the
paragraph level. It’s the difference (in code) of this:
<ul>
<li><span class="red">Red text, black bullets</span></li>
</ul>
and this:
<ul class="red">
<li>Red text, red bullets</li>
</ul>
You are better off using CSS to style the bullets. The List item Fix
action was originally written for FW 3 and is only really of any use
if you are stuck with FW 3 or 4.
To style your bullets in Freeway 5 or 5.5;
Select Edit/ Styles
Create a new style with li (list item) in the tag field and nothing
in the name field
Select color from the character section and add the bullet color
you want
OK the dialog and see your bullets in glorious color!
If the list items are in an html box called listcontainer (Under the first tab in the inspector with the html container selected look for Title)
Create a new style and in the Tag box type #listcontainer (or whatever your container is called) tab into the Name box and delete whatever FW has helpfully put in there for you. Tab out and check it doesn’t come back. Then add the Color option in the Character section and choose your colour.
OK the dialogues. Now whatever you have in the html box ‘listcontainer’ (or whatever you called it) will now be coloured with the colour you chose.
