Or even better you could use Weaver’s Fading Slideshow Action to make a slideshow that looks like Flash, only it’s Javascript and there’s an Action for it here:
If it’s SSP then it’ll have a SWF and an images.xml file that will need to be uploaded. Unless of course you’re using SSP Director which would require only the SWF.
I had never used Freeway and found Slideshow Pro through some posts from Dan J. (he’s the expert on this). If you can afford the extra $30, get Slideshow Director, it makes managing your images and uploading so much easier — outside of the initial install of Director to the root folder of your hosting site, all you have to do in Freeway is place the SWF file onto your freeway page (nothing else gets uploaded, since Director handles that). With Director you can easily update images to your site, swap out whole albums of images, add captions, etc.
Right, it’s a huge time saver. But you’ll want to make sure that the Eolas Workaround is unchecked if you do so because it causes a coding mess to appear in FireFox. It took me about three-four hours the other day trying to figure that trick out.
Who knew it’d be a little check-box causing the problem.
Has anyone run into the issue of Safari not showing the slideshow? I used an iframe and linked to the loader swf. It loads fine in FF, and IE but with Safari All I get is the space holder of the iframe and a little corner of text which I think is the slide shows title in the lower right corner.
thanks
DC
