I have removed the reference to the Classic stylesheet in the markup item.
Then I moved all the styles into Page>Html Markup in the before section and tweaked them to suit your requirements.
Also added the code to remove the active glow and added the active border colour.
Looks good!
So how should I paste the code into my site, exactly. Previously I’ve been putting the whole thing in ‘Insert’ then ‘markup item.’ Do I need to break it up and put some in the ‘HTML markup’ under the page menu?
Also do I grab the new code from viewing the page source and copying it there?
J
This is from mail chimp’s full form that I styled. I did not want to put something that large on one of my pages for a sign-up form but I liked the styling of the 3 text boxes so I thought that I would use the smaller classic form and adjust the styling to match the full form. For some reason mail chimp moved the asterisk to the inside with the classic form which I dislike.
Start creating “real” styles rather than fiddling them in inspector. This helps you in most cases, cause additional things often enough follow some simple rules (body, paragraph, headings 1-x).
